Matthew hurst
Briggs 10hp vertical engine
Matthew hurst
What is the carburetor setting for it.. :D :thumbs:
flex
play with the needle thats what i did on mine and its helped a lot
WH Raider10
I've a 11 hp briggs on my B-111,normally the carb should be the same on yours 10 hp. Here you have the initial settings: needle valve 1-1/2 turns open and the idle mixture valve 1 turn open. I hope this help you out.
Take care,
Pieter-jan from belgium :D :thumbs:
