TT-(Moderator) 1,170 #26 Posted December 6, 2010 But my tractor buddy said the cub runs in the opposet direction than a Horse? Is that true, anyone know? Just the starter/generator - since it drives/runs off of the PTO side instead of the flywheel. The engines all turn CW @ the flywheel. Share this post Link to post Share on other sites
jdog_kustoms 82 #27 Posted February 6, 2012 i figured id give this post a bump cuase this tractor is heading to my garage today and gona start it and i want to have it done by the show ansd more pics to come asap Share this post Link to post Share on other sites
jdog_kustoms 82 #28 Posted February 6, 2012 here are some pics of it as it is now before i tear it apart and do some custom work to it i will post pics as i go but im still desiding what engine to run in it maybe a 10 hp kohler maybe a 16 hp kohler maybe a honda clone maybe a twin 20 hp kohler k series Share this post Link to post Share on other sites
Jake Kuhn 1,599 #29 Posted February 6, 2012 Very cool project! :handgestures-thumbup: Share this post Link to post Share on other sites
AMC RULES 37,259 #30 Posted February 9, 2012 My vote would be for the twenty horse Kohler. :icecream: Share this post Link to post Share on other sites
jdog_kustoms 82 #31 Posted February 10, 2012 maybe a v twin diesel ??? i guess i got a figure what engine so i can mod the hood and frame and all to make sure it all works before i do other stuff might just use my 10 hp kohler keep other engines for other projects Share this post Link to post Share on other sites
jdog_kustoms 82 #32 Posted February 10, 2012 does anyone know of a satin or sorta flat wheel horse red paint Share this post Link to post Share on other sites
Hodge71 691 #33 Posted February 10, 2012 does anyone know of a satin or sorta flat wheel horse red paint Jordon, Krylon used to make Cherry Red in a satin finish. I used to get it at walmart a few years back Share this post Link to post Share on other sites
AMC RULES 37,259 #34 Posted February 15, 2012 Any progress yet? :text-bump: Share this post Link to post Share on other sites
jdog_kustoms 82 #35 Posted February 16, 2012 not yet iv been fixing my car hopefully soon Share this post Link to post Share on other sites
jdog_kustoms 82 #36 Posted July 13, 2012 well i picked up a set of wheels and tires for the project might be a little to wide they are 24x13-12 and the older ones are 23x10.5-12 the new tires are not even bolted on yet i need an aditional 3 inches for the wheel to be able to be bolted to the hub to customize or to not use them its a hard desition Share this post Link to post Share on other sites
Kelly 1,038 #37 Posted July 13, 2012 The one on the right is a 23x10.5 on the left is a 24x14x12, on a 8.5 rim off a 520 to give you a idea, they bolt on with no mods with those rims. Share this post Link to post Share on other sites
jdog_kustoms 82 #38 Posted July 13, 2012 ok so i take it the 520 rim has a lot smaller offset on the inside of the rim and i never new the 14 inch wide tires will fit on a 8.5 rim i have a set thats what was on it so ill have to smap the tires thanks kelly Share this post Link to post Share on other sites
Kelly 1,038 #39 Posted July 13, 2012 The 520 rims only have about 1.5" back spacing, if you look the rim on the right is a cub rim with more back spacing I think about 2.5" and I think it is a 8,5" rim also, and these tires are made for a zero turn with 8.5 rims they have a round sidewall maybe for a better ride, they would fit a wider rim I'm sure but I took them off a 8.5" rims with a 4 bolt pattern. Share this post Link to post Share on other sites
clintonnut 127 #40 Posted July 13, 2012 Do what I did with a command V-twin. WIll fit under the hood if you remove the shrouding. Charlie Share this post Link to post Share on other sites
jdog_kustoms 82 #41 Posted July 14, 2012 i think my v twin vanguard is gona go in it since i got a deal on it and cant seem to find a command near me for sale Share this post Link to post Share on other sites
COMMANDO6 20 #42 Posted July 14, 2012 Cool project. I say go with the 14 inch tires, The wider the better. 1 Share this post Link to post Share on other sites
roscoemi 245 #43 Posted July 15, 2012 Put those 14 wides on and you'll need an old mechanical injected 327 to burn them down properly and look wicked cool in the process! :teasing-poke: Share this post Link to post Share on other sites
jonsteffen 6 #44 Posted July 17, 2012 The one on the right is a 23x10.5 on the left is a 24x14x12, on a 8.5 rim off a 520 to give you a idea, they bolt on with no mods with those rims. go with the 24's looks more beefy 2 Share this post Link to post Share on other sites
Rooster 192 #45 Posted July 17, 2012 Use Da Big ones, big ones are better, they might attract another "tractor" with big ones.....just sayin', I'd use the big ones.... Share this post Link to post Share on other sites
jdog_kustoms 82 #46 Posted July 17, 2012 if i use the wide ones im gona cut the center out and move it but was also thinking when i move it to make the tires and wheels at close as i can to the rear end then cut the tool box down to give it like a mini tubed look like on a car think it would look ok or would you just move the center more to make them fit Share this post Link to post Share on other sites
Rooster 192 #47 Posted July 18, 2012 Tubbed, totally! I would not move them in though, I would widen the fenders :) Share this post Link to post Share on other sites
jdog_kustoms 82 #48 Posted May 28, 2016 well after 6 long years this tractor will be at the show not owned by me but built by me here is that it looks like as of today 1 Share this post Link to post Share on other sites
wallfish 20,031 #49 Posted May 28, 2016 Better get to work on it real fast quick and in a hurry! 6 years is enough procrastinating so now you gotta cram! 1 Share this post Link to post Share on other sites
jdog_kustoms 82 #50 Posted May 28, 2016 It will be done don't have tons of stuff to get ready for show anymore I might even stop in and make an appearance at the show 1 Share this post Link to post Share on other sites
