Countdown To Christmas!
Cessna
Steering question
Cessna
I was cutting the grass when I had to make a very sharp left turn. I heard a sound coming out of the steering column like the gear (steering) jumped out. Is this a common problem? How is it corrected?
C-Series14
Would help to know what tractor we are talking about but if it jumped a tooth on the fan gear, maybe there is too much up and down play. There is a collar below where the shaft goes thru the dash that can be loose...
Raider
My 312 will pop when I make a hard turn one way. I checked it out and it is the steering wheel shaft gear going past the end of the fan gear and jumping. Something is out of whack up front but I can't remember right now what it is, something with the tie rods or spindles allow the horizontal steering shaft to travel too far in one direction. I'll have to have a closer look before Winter rolls around.
C-Series14
You can shim the horizontal shaft behind the steering shaft mount. That will bring the fan gear closer to the steering shaft...
rickv1957
Is fan gear centered when wheels are straight,Rick
Kelly
The lower steering gear mount can have a broken ear where it is bolted to the frame, they jump then also.
