kloe0699 12 #1 Posted July 26, 2010 I'm having belt/pulley issues with my Raiders right now and the yard needed to be mowed. My buddy brought his new horse over today. I love it! It mows nice and gets into tighter spots than my 42" decks will. It doesn't like to pull 230lbs in thick grass up hills though Kevin Share this post Link to post Share on other sites
JimD 3,347 #2 Posted July 26, 2010 As long as she got the job done, that's all that matters. :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #3 Posted July 26, 2010 Them little V7s are a neat tractor!,Rick Share this post Link to post Share on other sites
wh500special 2,411 #4 Posted July 26, 2010 It doesn't like to pull 230lbs in thick grass up hills though Kevin Maybe you should of had a V8. Steve Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted July 26, 2010 Maybe you should of had a V8. :thumbs: Share this post Link to post Share on other sites
kloe0699 12 #6 Posted July 27, 2010 Maybe you should of had a V8. If that tractor had a V8 there would be no problems.. If I had a V8 it would cause a chemical imbalance. Kevin Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted July 27, 2010 It doesn't like to pull 230lbs in thick grass up hills though Kevin Give that Horse a beer! :D Share this post Link to post Share on other sites
kloe0699 12 #8 Posted July 27, 2010 Give that Horse a beer! Share this post Link to post Share on other sites
W9JAB 156 #9 Posted July 27, 2010 :thumbs: This is the first Horse I have seen with a vertical shaft engine Share this post Link to post Share on other sites
Roger from southern Iowa 1 #10 Posted July 27, 2010 My A 800 has a vertical engine also. Share this post Link to post Share on other sites
W9JAB 156 #11 Posted July 27, 2010 <_< learn something new every day I hate that! :D Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,849 #12 Posted July 27, 2010 This is the first Horse I have seen with a vertical shaft engine We had a member here who was known as the vertical Wheel Horse guy. And there are several verts in the picture gallery. Here are a few: 1969 Charger V8 1969 Commando V8 1970 Charger V8 1971 CG7 Not to mention late 60's early 70's Lawn Rangers, the A-series, the late 70's B-series, etc. Share this post Link to post Share on other sites
