Countdown To Christmas!
JUSS10
first round hood restoration
JUSS10
im going to turn my own bushing on a lathe out of UHMW
JUSS10
little update. thanks to this crazy heat and humidity in michigan i haven't been in the barn much working on the tractor. well i finally decided who cares and went at it. well the barn was trashed so first i cleaned it up and re arranged everything. much more functional now.
as for the 753 i was able to get the steering all in. everything is pretty tight except where the shaft that runs the length of the frame has a lot of play at the fan gear end where it goes into that bracket. guess I'll be turning a bushing to compensate for all the wear. found a brass bushing that fit well in the tank so that was nice. got the brake band on and finally made it a rolling tractor after playing musical tires with a few tractors. picked up a parts tractor that i think has nicer spindles on the front so this will probably get moved to this tractor as well.
whats left:
- spring for the clutch
- drive belt
- seat painted
- finish the wiring
- body work on the hood and painted
- wheels stripped and painted
- fenders sand blasted and painted (not a big fender fan so that may not happen..)
and thats about it. hopefully in the next week it can be driving.
DMK855
Looking good Justin!! :) I like the brass bushing idea!! I need to find me a couple of those!!
JUSS10
the bushing was a 3/4 ID and 7/8 OD. a little epoxy and it was a tight fit in the tank :)
rustynut
what kind of paint did you use
JUSS10
restoration series IH red with hardener. sprayed with a gun
