Countdown To Christmas!
N.C. horserider
Tie rod ends
N.C. horserider
Does anybody know where or if the original tie rod ends can be replaced and where I might find them
rickv1957
New adjustable tierods are available fom toro,about 30.00,Rick
GlenPettit
Most common problem is that the 'Ball' comes out of the 'Shaft pocket'.
If that's your problem, it is an easy fix: place the tube in a vice, socket up, lub and replace the ball into the socket, use a center punch and "ping-over" the socket edges all around so they gently lock in the ball, but it can still easily move.
Some people have remade their own tie-rods (time & equipment), otherwise it is best to buy the new adjustable ones as mentioned above, there are often pairs for sale on eBay, under Wheel Horse.
Good Luck, Glen
clintonnut
$15/pr at tractor supply!
Charlie
N.C. horserider
OK guys I'll check out these options and see what I come up with thanks.
