rdd52 0 #1 Posted July 22, 2010 does anybody know if they still make the diaphragm's or gaskets for the fuel pump for a kohler 7hp engine?and were i can get them? i want to take it apart and clean it because the carb. and gas tank had a lot of varnish in them. Attached Image Share this post Link to post Share on other sites
rmaynard 17,027 #2 Posted July 22, 2010 I believe they are available as an after-market product. I will get back to you after I contact another member that has them. Bob Share this post Link to post Share on other sites
buckrancher 2,696 #3 Posted July 22, 2010 I make the diaphragm ($5.00) for the vacuum pumps pm me if you want one Share this post Link to post Share on other sites
squonk 45,937 #4 Posted July 22, 2010 I make the diapham ($5.00) for the vacuum pumps pm me if you want one What about the rest of the gaskets? My vacuum pump on my k161 is bad also. The local "Kohler Guru" could not get a pump or a kit. Mike Share this post Link to post Share on other sites
buckrancher 2,696 #5 Posted July 23, 2010 I make the diapham ($5.00) for the vacuum pumps pm me if you want one What about the rest of the gaskets? My vacuum pump on my k161 is bad also. The local "Kohler Guru" could not get a pump or a kit. Mike In the vacuum diaphragm pump the only gasket is the diaphragm the other parts are two small round pucks an two springs you can fix the pucks if they are grooved by lightly sanding them on a piece of glass using 2000 grit sandpaper Share this post Link to post Share on other sites
