Countdown To Christmas!
B-8074
69 Charger 12 Hydro
B-8074
I found a nice Charger 12 with hydro and a really nice side discharge deck. The hydro fluid was real clean also. The only thing it needs is rewired. I was wondering if my plow off my 74 B-80 would fit that tractor and if the hydros are good for pushing dirt and snow? I'm gonna pick it up later today and I'll post some picks then. :thumbs:
rickv1957
Charger is a long frame,B80 is a short frame,maybe your plow has the blade frame for both ,Rick
B-8074
The plow and frame I have mount to the rear axle and the lift handle.
rickv1957
Some of the blades were made so you could remove the pin that goes into the rear attach to another set of holes in blade frame to allow blade to be used on both short and long frame tractors,Rick
B-8074
Thanks Rick, Took a second to process.
DMK855
I purchased a Charger 12 a little while back and am very pleased with with it! I am sure you will be happy with it if you get it!!
As far as the plow goes, like Rick had mentioned, if you have a plow that fits long and short frame tractors, you will be golden!!
B-8074
Well it took longer than I wanted but I got my 69 Charger 12 home. Like I said
before all it really needs is rewired.
rickv1957
Tractor looks good!! :thumbs: Rick
