Polaris2007 4 #1 Posted July 16, 2010 Okay, I have this 10hp K-series Kohler, and it has a rapping sound coming from somewhere within. It runs like an absolute dream. No smoke whatsoever. So I'm thinking worn rod bearing? bad case of piston slap? Anyway, I want to rebuild it, and I'm considering boring it out even if it doesn't need it, for the reason of gaining horsepower. If I were to bore a 10hp Kohler .030 over, how much hp would be gained with no other modifications? Probably not enough to make it worth the money for a new piston/rings and the machining costs? Are we talking about a fraction of a hp gain, or would it instantly become a 12hp? Any thoughts? :thumbs: Share this post Link to post Share on other sites
WH854 45 #2 Posted July 17, 2010 Go to this web site and read how you can do what you are asking. http://gardentractorpullingtips.com/index.htm This will answer your question. Chas :D Share this post Link to post Share on other sites
Docwheelhorse 2,847 #3 Posted July 17, 2010 I don't know how much HP you will gain... I don't think much of any as the longer stroke in combo with the bigger bore makes the extra HP in the 12/14. I also think that if you bore it "thirty" over you will have bored the block to its max leaving no room for future rebuilds should it get scored or wear itself out. Just my thoughts Tony Share this post Link to post Share on other sites
rickv1957 77 #4 Posted July 17, 2010 Dont think you would even feel the .30 overbore,Rick Share this post Link to post Share on other sites
big mike 13 #5 Posted July 17, 2010 I would bore it if it needs bored but not soley for a power boost. Share this post Link to post Share on other sites
rmaynard 16,836 #6 Posted July 17, 2010 I also think that if you bore it "thirty" over you will have bored the block to its max leaving no room for future rebuilds should it get scored or wear itself out. Don't know if you can get a bigger piston, but the K241 is built on a K301 block. Should be able to bore to the maximum allowed on the K301 without problems. If I am wrong, someone please correct me. Bob Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted July 17, 2010 I agree with Rick..... if you bore 30 over for performance reasons you'll be not impressed. Share this post Link to post Share on other sites
jdog_kustoms 82 #8 Posted July 17, 2010 I also think that if you bore it "thirty" over you will have bored the block to its max leaving no room for future rebuilds should it get scored or wear itself out. Don't know if you can get a bigger piston, but the K241 is built on a K301 block. Should be able to bore to the maximum allowed on the K301 without problems. If I am wrong, someone please correct me. Bob some 10 hp are k301 (12hp ) blocks not all so check before you bore but if it is a k301 block 10 hp motor it might be cheaper to just install a stock 12 hp piston on it Share this post Link to post Share on other sites
rmaynard 16,836 #9 Posted July 17, 2010 Right you are Jordon. Look behind the PTO plate for the embossed "K301" to be sure. Bob Share this post Link to post Share on other sites
