kal1551 0 #1 Posted April 1, 2008 I would like to add an LED implement light to the rear of my 85' 312-8; would the small variation in voltage effect the LED. In essence, is it possable to add an LED? OR do I just find an LED light that ranges between 12 and 16 volts? Any help would be great! Thanks in advance!! Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted April 1, 2008 A 12V LED light for automotive/truck applications will work fine. The sealed beam headlight bulbs are "rated" at 12V. If you intend to hook the rear light up to a separate switch, you can power it off the same wire that "feeds" the headlight switch. Share this post Link to post Share on other sites
