Fuzzyphi 0 #1 Posted July 10, 2010 I have a C-81 that has recently stopped working properly. It only runs at idle. When I start it up cold I can go full throttle and it will rev for a second before backing down to idle. After it's warmed up it stays at idle, no matter what I do with the throttle. The throttle cable is working. I have adjusted the governor per the manual. Any suggestions? I assume it's a governor problem, but I don't really know much. I'm still learning the tractor. Thanks for the help in advance. -Cory Share this post Link to post Share on other sites
rmaynard 17,027 #2 Posted July 10, 2010 When you adjust your throttle, is the throttle shaft on the carburetor rotating? Is the linkage between the governor arm and the throttle shaft connected? Bob Share this post Link to post Share on other sites
rickv1957 77 #3 Posted July 10, 2010 Sounds like something has come loose on governor,maybe the large nut that holds the throttle cable bracket,Rick Share this post Link to post Share on other sites
Fuzzyphi 0 #4 Posted July 11, 2010 When you adjust your throttle, is the throttle shaft on the carburetor rotating? Is the linkage between the governor arm and the throttle shaft connected? Bob The throttle moves fine when the tractor is turned off. Move the throttle and it moves on the carb. Share this post Link to post Share on other sites
rickv1957 77 #5 Posted July 11, 2010 When you adjust your throttle, is the throttle shaft on the carburetor rotating? Is the linkage between the governor arm and the throttle shaft connected? Bob The throttle moves fine when the tractor is turned off. Move the throttle and it moves on the carb. Sounds like you have lost adjustment somewhere,Rick Share this post Link to post Share on other sites
jimt1971 237 #6 Posted July 11, 2010 How old are the fuel lines. With the newer fuels the lines are colasping inside. So they will look good on the outside but will be clogged inside. Jim :thumbs: Share this post Link to post Share on other sites
Fuzzyphi 0 #7 Posted July 11, 2010 How old are the fuel lines. With the newer fuels the lines are colasping inside. So they will look good on the outside but will be clogged inside. Jim The fuel lines are all less than a year old. I can manually rev the engine by moving the lever on the carb. Share this post Link to post Share on other sites
rickv1957 77 #8 Posted July 11, 2010 Can you post a picture of your carb-governor setup,Rick Share this post Link to post Share on other sites
oldandred 16 #9 Posted July 11, 2010 How old are the fuel lines. With the newer fuels the lines are colasping inside. So they will look good on the outside but will be clogged inside. Jim The fuel lines are all less than a year old. I can manually rev the engine by moving the lever on the carb. Check the clapm that holds the cable tight to the piece of metal if its lose the cable will move up and down Share this post Link to post Share on other sites
Fuzzyphi 0 #10 Posted July 11, 2010 Hopefully this works. I've tried to post a link to a video of my governor/carb. Sorry about the low quality. WH Governor Video Share this post Link to post Share on other sites
Fuzzyphi 0 #11 Posted July 11, 2010 I've posted another video below to show what it is doing while running. WH Governor - Running Share this post Link to post Share on other sites
rickv1957 77 #12 Posted July 12, 2010 Everything looks right from what I see on the outside,Rick Share this post Link to post Share on other sites
