jdog_kustoms 82 #1 Posted July 10, 2010 will an old deck off a charger or bronco work with a attach a matic and front mule or do i need a new deck also if i update my bronco to atach a matic front and mid Share this post Link to post Share on other sites
rickv1957 76 #2 Posted July 10, 2010 You can take all the deck mounting brackets from a newer deck and install on original deck,takes some work,Rick Share this post Link to post Share on other sites
jdog_kustoms 82 #3 Posted July 11, 2010 just for everyones info the newer attach a matic setup will except the older decks and the front mule will work with those decks also pics to follow Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted July 11, 2010 The one thing you do have to watch is interference between the deck drive belt and the little "chair leg glide" height stop between the mounting carriage and the deck shell. Since the early decks were made to be driven by the belt coming in more from the right side instead of the front, the adjuster wasn't a concern. Share this post Link to post Share on other sites
jdog_kustoms 82 #5 Posted July 11, 2010 heres a pic tt what are you callin the chair leg guide Share this post Link to post Share on other sites
rickv1957 76 #6 Posted July 11, 2010 You do have the original type deck with the newer style attach a matic,looks good, looks like the chair leg has been removed,Rick Share this post Link to post Share on other sites
jdog_kustoms 82 #7 Posted July 11, 2010 yeah the older deck fit on my 416-8 with the attachomatic so i figured if it worked there then i mit as well put all the attach a matic stuff on the bronco so i can ran any attachment i wanted Share this post Link to post Share on other sites
