tmix
Mower DECK Dilema!!
tmix
The Old Lady was cutting grass the other day, I could hear a funny sound coming from the lawn mower could not figure what it was. I had her stop a few times could not hear the sound only when she was cutting every now and then i could hear it . The deck is a 36" model 5 2362 Serial 528808 Come to find out the blades are hitting each other every now and then. Are these blades suppose to be straight across from each other or opposite from each other . They are straight right now they are gear driven AND SUGGESTIONS !!!! :thumbs: T MIX
rickv1957
They are suppose to be timed 90 degrees apart,Rick
tmix
Thanks i'll try to rotate them somehow :thumbs:
rickv1957
Been a while on the gear drives but I think you can remove gear cover,remove snap ring,drop down spindle and rotate,Rick
dkopp
Check for missing teeth and or count the number of teeth on both the face and spur gears.
WH nut
The problem with removing the snap ring is the wooddruff key. Ypu either need to loosen up the top mounting and raise the side gear or grind the key down a little to get the clearance. If its out of time, either the teeth are worn, or the cast mounting is broken
Jim_M
The first thing I would check is the woodruff key. It's probably sheared.
