Posimoto 5 #1 Posted June 29, 2010 I have a 42 RD and found a diagram of a recycler while doing a search but not a lot of info with it. http://www.wheelhorseforum.com/index.php?...215&hl=recycler Do they come available often? Are they most often sold with or without decks? Can a deck with a recycler use the same blades as non-recycler deck? Maintenance? Price range? Any other info you feel would be helpful is much appreciated. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,528 #2 Posted June 29, 2010 They are only offered on the 42 rd decks. If your deck has baffles they will need to be cut out in order for the insert to fit. The blades are different than the normal blades used. It takes 4 bolts to install it. I personally love mine and would not sell it ever. You have to cut it low and tight and go slow in order for it to work right. I do not pick up leaves any longer. Last year at the show we found 2 of them and this year I saw none. If you find one, buy it. Good luck- Share this post Link to post Share on other sites
