runrider 0 #1 Posted June 22, 2010 I'm sitting on my tractor in the garage, defeated by 4 out of 5 rear wheel lugs. How do I get them off? They are kind of in the wheel well, so I can only fit a small ratchet on them, and I cant get much torque on that little ratchet. I can put an extender on the ratchet, but I'm finding it difficult to keep the ratchet perpendicular to the wheel - it just wants to slip off that little wheel lug. Surely many of you have been here before, how did you get it? Special tool? Share this post Link to post Share on other sites
oldandred 15 #2 Posted June 22, 2010 I'm sitting on my tractor in the garage, defeated by 4 out of 5 rear wheel lugs. How do I get them off? They are kind of in the wheel well, so I can only fit a small ratchet on them, and I cant get much torque on that little ratchet. I can put an extender on the ratchet, but I'm finding it difficult to keep the ratchet perpendicular to the wheel - it just wants to slip off that little wheel lug. Surely many of you have been here before, how did you get it? Special tool? get one of them four way lug thing that every body need to cary in there car Share this post Link to post Share on other sites
rickv1957 76 #3 Posted June 23, 2010 I'm sitting on my tractor in the garage, defeated by 4 out of 5 rear wheel lugs. How do I get them off? They are kind of in the wheel well, so I can only fit a small ratchet on them, and I cant get much torque on that little ratchet. I can put an extender on the ratchet, but I'm finding it difficult to keep the ratchet perpendicular to the wheel - it just wants to slip off that little wheel lug. Surely many of you have been here before, how did you get it? Special tool? get one of them four way lug thing that every body need to cary in there car That ought to do it! Rick Share this post Link to post Share on other sites
rmaynard 16,574 #4 Posted June 23, 2010 Spray a little PB Blaster on it, front and back. Let it sit a bit. Then make sure that you have a good 5/8" socket with a long extension and a breaker bar (longer handle). Keep it as straight as possible while applying pressure. Otherwise, get a 4-way lug wrench with a 5/8" end as stated above. If all else fails, load it up in the back up the truck or trailer and take it to a tire shop or garage where they can use an air impact wrench. When you put the wheels back on, be sure to put a little anti-seize on the threads before installing the bolts. Bob Share this post Link to post Share on other sites
tgranthamfd 29 #5 Posted June 23, 2010 If you find a 4 way with the right size, let me know. I couldn't find one anywhere around here. Everything was metric or just to big. I had a new hub on 1 of mine when I bought it, I like to have never got one of them off with a 3/8" ratchet, 4" extension, and a deep 5/8" plug socket. The other 4 came out pretty easy. Share this post Link to post Share on other sites
MaineDad 87 #6 Posted June 23, 2010 Like Terry said... Long extension and a deep 9/16 socket... Share this post Link to post Share on other sites
jpmcleod 4 #7 Posted June 23, 2010 I know we have all read discussions before about trying to get the rim to sit on the hub while starting the first lug nut. It become frusterating. I tried something different the other day and it worked great. I screwed a lug in from the back and it stuck out enough to hang the wheel on it untill I got the other four on tight. I then backed out the reversed lug and screwed it in correctly. The rim never fell off the hub like it always did. In rgards to the frozen lugs, PB Blaster, an extention and a 5/8 socket and you should be able to get them off. Good luck. I have been there several time fighting with rusty lugs. Share this post Link to post Share on other sites
The Toolman 22 #8 Posted June 23, 2010 Thin Wall 6 point 5/8 socket for a 1/2" drive rachet an extension Share this post Link to post Share on other sites
runrider 0 #9 Posted June 24, 2010 Impact wrench? now theres a good idea. I managed to get it off by prying my wrench - they werent stuck, just difficult to get at w/ a dog bone or a small ratchet. I need a set of impact wrenches. Too bad I snapped one of the bolts that holds my brake band to the tranny :thumbs: Share this post Link to post Share on other sites
rmaynard 16,574 #10 Posted June 24, 2010 While you are out shopping for that impact wrench, get yourself a 15/64th drill bit and a 1/4" tap. Drill out the broken bolt and retap the threads. Bob Share this post Link to post Share on other sites
tarcoleo 119 #11 Posted June 24, 2010 "Too bad I snapped one of the bolts that holds my brake band to the tranny :-(" -------------- That happened to me. Drilling out the broken 1/4" bolt is easier said than done. Tried that with a long drill, access is difficult, broke the drill in the transmission boss. So with only one bolt to hold the brake strap it was necessary to make a custom brake strap that wrapped around (hooked on to) the boss and was held in place with just the one bolt. Works fine now. The hook on the boss holds the strap against the strongest braking situation. Those 1/4" bolts rust out easily and should never be removed without a lot of PB Blaster first applied. Tom in RI :thumbs: Share this post Link to post Share on other sites
rmaynard 16,574 #12 Posted June 24, 2010 Can't speak for anyone but myself, but if you want to do it right, take the transmission out and you have easy access to the mounting boss. You will never be able to have enough control of a long drill bit when trying to drill out a broken bolt. Just my 2 cents worth. Bob Share this post Link to post Share on other sites
tarcoleo 119 #13 Posted June 24, 2010 Bob, I can certainly confirm your advise re a long drill. But taking the tranny out in order to properly drill out the broken bolt was NOT something I cared to do. Much easier to re-engineer the brake strap. I extended the length of the brake strap so that there was enough material to hook onto the tranny boss. With the one remaining 1/4" bolt, plus the hook, the brake strap was secured and not "going anywhere" under any braking situation. Maybe not "right", but it works. Tom in RI Share this post Link to post Share on other sites
SAM58 31 #14 Posted June 24, 2010 USE A 4 WAY LUG WRENCH, THE SMALLEST SIZE SHOULD FIT. LET SOAK WITH PB BLASTER, AIRKOIL, OR A REALLY GOOD PENITRATING OIL FOR ABOUT 30 MINUTES.... :thumbs: Share this post Link to post Share on other sites
rmaynard 16,574 #15 Posted June 24, 2010 Bob, I can certainly confirm your advise re a long drill. But taking the tranny out in order to properly drill out the broken bolt was NOT something I cared to do. Much easier to re-engineer the brake strap. I extended the length of the brake strap so that there was enough material to hook onto the tranny boss. With the one remaining 1/4" bolt, plus the hook, the brake strap was secured and not "going anywhere" under any braking situation. Maybe not "right", but it works. Tom in RI That's the sign of a true mechanic. Work with what'ya got. Sometimes the over-engineered product can be fixed to work just as well with a little American ingenuity, a lot of duct tape, and a little luck. Glad you got it working. Bob Share this post Link to post Share on other sites
