suxatpball 0 #1 Posted June 19, 2010 Ive got a B80 not sure of the year (cant read the ser#) its a 4 speed. Anyway the previous owner put in wrong spark plug and the other day it shot out of the head. Im looking for a new head and am wondering what kohler motor it came with. Im thinking it was the K181 but am not sure. Can you confirm or deny this??? Share this post Link to post Share on other sites
rmaynard 16,533 #2 Posted June 19, 2010 You don't need the serial number to date the machine, just the model number. Since the 4 speed was only available in 1974 & 1975, it has to be one of those years, unless of course someone put a 4 speed in a later model. The model number would be either 1-0140 or 1-0145 for a 1974, and 1975 would be 1-0141. '76 & '77 started with the prefix 61 & 71 respectively. The B-80 came with the K181S. If someone here does not respond with a head for you, I have seen them on eBay. Bob Share this post Link to post Share on other sites
JimD 3,347 #3 Posted June 19, 2010 Actually, the B-80 came with a K-161 engine, or 7 horse. I would post in the classifieds here first for a used head, and then keep an eye on ebay for one. I'm thinkin somebody here will have one they would part with. Edit: I should know better than to go from memory, I was thinking of my B-60. Sorry for the confusion. :D Share this post Link to post Share on other sites
suxatpball 0 #4 Posted June 19, 2010 so i have the k181? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted June 19, 2010 Originally, the B-80 models all had K-181 Kohler 8hp engines. You don't have to buy another head if you - or a local repair shop - can fix yours. http://www.wheelhorseforum.com/index.php?showtopic=13899 If you do decide to buy a used part, be careful you don't end up with the same problem. Either way, make sure you install a new head gasket and torque the bolts in the proper pattern to 15 to 20 ft-lbs (and retorque them after the engine has reached operating temperature and cooled again) Share this post Link to post Share on other sites
rueger-99 0 #6 Posted June 20, 2010 Pull the head and bring it down to your local auto parts store and tell them you want a Heli-coil kit to repair the spark plug threads. It's an easy fix. Might as well clean the top of the motor up now that it's apart and slap on a new head gasket. Share this post Link to post Share on other sites
WH nut 553 #7 Posted June 23, 2010 I have had problems with helicoils on the K161, I just watch ebay and pick up a head or two for a spare. I actually had a buddy weld up the plug hole on one and I retapped it. That one is still going Share this post Link to post Share on other sites
WH nut 553 #8 Posted June 23, 2010 http://cgi.ebay.com/John-Deere-110-8-HP-Ko...=item4aa25efe09 Here you go Share this post Link to post Share on other sites
