Olratlr 25 #1 Posted June 17, 2010 Can any one tell me what Tillers would fit a Raider Nine 1968 -1-6931 I can't seem to find the tiller serial numbers for it. Thanks. Norm :D Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted June 17, 2010 Model # 7-1211 - 36" Tiller was originally designed for that tractor, which supersedes to Model # 7-1252. The currently available Toro models are 07-36TL05 and 79370 Others will chime in with units which will also work for you. I suspect most 36" tillers would work with some minor modification to mountings and drives. Share this post Link to post Share on other sites
stoneman 10 #3 Posted June 17, 2010 http://www.mytractorforum.com/images/refer...interchange.pdf this may help Share this post Link to post Share on other sites
Olratlr 25 #4 Posted June 17, 2010 Well I called the Gentleman and he say's the tiller is for a Work Horse model and here is the Serial # he gave me and I can,t find it on the Charts. 97-TL01-10709' Thanks to you for the information I received. :D Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted June 17, 2010 Try 97-36TL01 That would be a (1979) 36" tiller. It is a direct fit on the C series, 300/400/500 models, and the WorkHorse GT models. It will work on your Raider, but you might need a shorter drive belt (smaller PTO clutch pulley) if the tensioner doesn't travel enough to compensate. You might also have to get creative on the lift cable to tiller attachment since this tiller was made to be lifted by a chain from an under-fender bellcrank. Share this post Link to post Share on other sites
Olratlr 25 #6 Posted June 17, 2010 You guys are great I will try to get it and use on my 520H. Norm :USA: Share this post Link to post Share on other sites
