dgjks6 8 #1 Posted June 12, 2010 looking for some new bearings for a 312-8 transmission. The master parts viewer lists 111199 and 1533. Are these the same part or is one for the 1 1/8 inch and one for the 1 inch? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #2 Posted June 12, 2010 I believe the 111199 was first used in 1986 and has a 40mm ID. The 1533 has a 1-1/2" ID and was used from 1961 up except for a few that used a roller bearing during a parts shortage. Try the parts lists at http://www.partstree.com/parts/ Sometimes they do a better job of separating the models. Type Toro in the 2nd box and the long model number in the 3rd box. Garry Share this post Link to post Share on other sites
dgjks6 8 #3 Posted June 12, 2010 You are correct, sir. thank you. Will have to use parts tree more often. Share this post Link to post Share on other sites
