ericschevy 0 #1 Posted June 11, 2010 Hey guys, I just picked me up a C-141 (8 speed manual)and noticed there is water deposits in the trans. What type of fluid do I use in it? Thanks.. Share this post Link to post Share on other sites
C-Series14 15 #2 Posted June 11, 2010 Lube and belt chart says 2 qts. SAE 90-140 API Service GL-5 Gear Lube Share this post Link to post Share on other sites
Duff 206 #3 Posted June 12, 2010 Eric, you probably already knew this, but flush that tranny really well before adding the new lube! Duff :D Share this post Link to post Share on other sites
The Toolman 22 #4 Posted June 12, 2010 put a new boot on the shifter to stop that water getting in Share this post Link to post Share on other sites
ericschevy 0 #5 Posted June 12, 2010 put a new boot on the shifter to stop that water getting in Yeah, I later realized that the boot is missing. What's worse is that this tractor had been stored outside..YIKES!! Share this post Link to post Share on other sites
ericschevy 0 #6 Posted June 12, 2010 Eric, you probably already knew this, but flush that tranny really well before adding the new lube! Duff Would it be safe to use engine flush? All it is kerosene.. Share this post Link to post Share on other sites
rickv1957 74 #7 Posted June 12, 2010 That will work fine,I use deisel fuel,Rick Share this post Link to post Share on other sites
