brider 0 #1 Posted June 10, 2010 OK, I'll admit that I haven't bought a manual yet, but I figure the parking brake can't be that hard to adjust, can it? My tractor will hold a hill going forward with the parking brake on, but not backward; it will roll slowly over me while hitching a trailer if the hill is even slight. How is this adjusted? Share this post Link to post Share on other sites
rickv1957 77 #2 Posted June 11, 2010 Park brake is non adjustable,on the sunstrand trans most park pawls in trans have been ground off over the years where they dont work right or not at all,you have to open trans to repair or replace pawl,Rick Share this post Link to post Share on other sites
brider 0 #3 Posted June 11, 2010 OOOOOOhh, so the parking brake relies on the transmission hydraulics? Is it common or possible that in my case, these "pawls" wore in one direction (allowing movement in reverse), and not the other? Share this post Link to post Share on other sites
rickv1957 77 #4 Posted June 11, 2010 Park has nothing to do with hyds,it relies on a mechanical stop between the teeth on a trans gear when park brake is set ,Rick Share this post Link to post Share on other sites
