Countdown To Christmas!
jpmcleod
Belt tension
jpmcleod
I have 2 C-175's and a Bronco 14 hydros. The Bronco 14 and one of the C-175's have a T-handle that you push down to put tension on the drive belt and pullnup to release tension. One of my C-175's does not have the push-pull handle although the slot in the shifter plate is there. I have examined the pully bracket and it does not appear to have a handle broken off. I don't know the production years of either C-175. My question. The C-175 has a spring that puts downward tension on the belt at all times but the belt keeps comming off. Is this correct or is something missing.
refracman
It should have the same setup as the bronco.
jpmcleod
That is what I thought but looking at the pulley bracket, I can't find where the handle would have broken off. I will get with Davoman and he should have a pully with a handle.
Thanks for the response.
