dandan111
6 hp tecumseh dies
dandan111
My 654 runs and mows great but when it gets hot, 1/2 hour or so it starts
to sputter and dies. After it cools down its the same story,runs great till
it gets hot and dies..... It was in long term storage so I put a good carb
on it,I have adjusted as recomended and it runs great until it gets hot.
Any suggestions?Maybe its time to let somebody else work on it.
The motor is a H-60
I love using it, if it would run and not die it is perfect for my lawn.
TT
How long has it been since the condenser was replaced?
Docwheelhorse
I agree with TT.... its time for points and condensor. What you describe is a classic condensor on the way to dirt nap city.
Tony
dandan111
Condenser, no idea on that. Is it easy to replace? Can I clean the points?
I cleaned the bottom power valve on the carb a little while ago. If it
needs point and a condensor it may need to go to a shop.
I will be mowing again in a few days(thats when I have the trouble)
Gene_S
Its under the fly wheel on the Tecumseh motor Danny... You might see if Richard wants to fix her if you don't want to... Good luck...
dandan111
Thanks gene,It may be more than I want to tackle.
