Wheel Horse wanna-be 0 #1 Posted May 31, 2010 :D I reversed polarity by hooking up battery wrong. Motor started a couple of times. Won't turn over now. Have I damaged anything? Share this post Link to post Share on other sites
mavfreak 11 #2 Posted May 31, 2010 probably. I had an Honda 350 that I was fixing up. Got a new battery and hooked it up wrong as soon as I hit the key the wiring was gone. Needless to say I sold bike as a parts bike for just about what I bought battery for. I really learned my lesson there. At least wiring is pretty simple on these and I'm sure if save old iron sees this post he'll help you. He knows what hes doing so pay attention :D Share this post Link to post Share on other sites
Save Old Iron 1,568 #4 Posted May 31, 2010 SOI here, taking a break from some serious holiday grilling ! Well, I have to admit I have zero practical experience with starter gen style tractors, BUT, that will change with my newly acquired $50 800 Special. What I would like to see is a schematic of the tractor wiring. In the meantime, I would remove the drive belt from the starter gen and with no physical connection between the engine and the S/G 1/ see if the engine turns over by hand - is the engine mechanically locked up ? 2/ does the starter generator spin correctly when you turn the ignition key to the start position ? 3/ carefully inspect ALL the wiring to the S/G unit for breaks and burns and possible loose or corroded wiring. Let us know Got to go - the Brauts are whistling on the grill . Share this post Link to post Share on other sites
Wheel Horse wanna-be 0 #5 Posted May 31, 2010 :D Well, here we go. Bought 2 WH on Friday. Iinstalled atest battery and the tractor had a red and black cable. Red is positive, right? Hooked it up, shot some etherand motor ran a little. Decided to charge battery and than noticed red cable was on Neg. post. Changed connections, charged battery and nothing happened. Sent message on Red Square for help. Started to test 2nd tractor and noticed it had 2 black cables. Started to go online and find wiring diagram and found 1 in a manual that came with tractor. Found that red cable didn't belong on tractor and as it was, it was on the wrong polarity. Put battery back in 1257 with original connections. Gave it some ether and it kicked over. All is OK, need some carb. work but am happy camper. Also got 2nd tractor running and drove it around. 1out of 2 is OK. Now need info on carb, any links would help. Thanks SOI for responding. **** Share this post Link to post Share on other sites
Horse Fanatic 51 #6 Posted June 1, 2010 Don't rely on the cable color to determine what cables go where. Look where the cables go, the positive goes to the starter solinoid and the neg goes to the tractor body. Also, don't use ether to start a small engine! Use aerosol carb cleaner. Share this post Link to post Share on other sites
Kelly 1,033 #7 Posted June 1, 2010 Don't rely on the cable color to determine what cables go where. Look where the cables go, the positive goes to the starter solenoid and the neg goes to the tractor body. Also, don't use ether to start a small engine! Use aerosol carb cleaner. What he said on all counts. At least the neg goes to ground someplace, and pos. to the solenoid or starter switch. Share this post Link to post Share on other sites
Wheel Horse wanna-be 0 #8 Posted June 1, 2010 Wasn't asking for a lecture, just letting you know the problem is solved. Thanks SOI Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted June 1, 2010 We were not giving you a lecture, just letting you know Ether can ruin a small engine, very fast. Share this post Link to post Share on other sites
Buzz 502 #10 Posted June 1, 2010 Here's your Kohler service manual, has a good section on carburetors. http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf Share this post Link to post Share on other sites
Wheel Horse wanna-be 0 #11 Posted June 2, 2010 Thanks Buzz, just what I needed. Share this post Link to post Share on other sites
tgranthamfd 29 #12 Posted June 4, 2010 There are a couple of good downloads on the carb situation here, as well. http://www.wheelhorseforum.com/index.php?showtopic=18400 Very informative posts for me. Share this post Link to post Share on other sites
