stamplicker 0 #1 Posted May 29, 2010 I have a Wheelhorse 417-8 that the gear shift leaver pulls out of the transmission case. Can anyoue give me some information as to how to repair this? Can complete new transmissions be purchased and if they can who sells them. I could also use a parts break down if available. Thanks. Luther Share this post Link to post Share on other sites
rickv1957 75 #2 Posted May 29, 2010 Hello and There is a little set screw that holds shifter in,located at where shifter ball sets in trans,easy fix,Rick Share this post Link to post Share on other sites
rickv1957 75 #3 Posted May 29, 2010 Set screw bottoms into hole on front side of shifter ball, just snug up enough that shifter movement does not get too tight,then tighten jam nut, Rick Share this post Link to post Share on other sites
Duff 206 #4 Posted May 31, 2010 Hi, Luther and ! Just so you don't think the set screw is broken off, it actually takes a small Allen wrench to loosen/tighten it. As to assembly drawings, go to: https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro and enter 31-17K801 in the Model Number window. Good luck! Duff :D Share this post Link to post Share on other sites
