TT-(Moderator) 1,173 #27 Posted May 30, 2010 Excellent job! Don't forget the spacer / longer bolt for the top of the coil bracket...... I'd hate to see the coil fall back on to the battery because the mounting plate broke. :USA: Share this post Link to post Share on other sites
MikesRJ 563 #29 Posted May 30, 2010 :wh: What a pretty ride. Great job! :USA: Share this post Link to post Share on other sites
blaster 0 #30 Posted May 31, 2010 Excellent job! Don't forget the spacer / longer bolt for the top of the coil bracket...... I'd hate to see the coil fall back on to the battery because the mounting plate broke. Thanks Terry, I thought something didn't look right in the bracket area. You're right there's supposed to be a spacer with a longer bolt. This thing was apart all winter as I could only work on it a little at a time and there was many times I was scratchin my head. Thanks...Glenn Share this post Link to post Share on other sites
C-Series14 15 #31 Posted May 31, 2010 Yours is awesome!!! :D Share this post Link to post Share on other sites
mnWHfan 47 #32 Posted June 3, 2010 Good job on your tractor, it looks great. Share this post Link to post Share on other sites
dclarke 4,274 #34 Posted June 3, 2010 Glenn, your b-80 turned out awesome. great job. :D Share this post Link to post Share on other sites
bustedglass 2 #36 Posted June 5, 2010 You did good. It looks GREAT !!! . Share this post Link to post Share on other sites
JimD 3,347 #37 Posted June 5, 2010 Looks fantastic! :D Share this post Link to post Share on other sites
