dustycarter
Wheel Horse 312-8 3 pont help
dustycarter
Hello. I need some help on how to make one. I am wanting a 3 point for my 312-8. I am just planning on pulling a box blade and a scraper. Just need to know ho to make the frame and how to attach it to the main frame. I also would need the lifting guide. where you hook the rocker arm to the frame and then the arms go up and down. Pictures, plans, posts anything would be very helpful. Thank you very much for all the replys.
Kelly
There is a member here that makes 3 points to fit your tractor, look in the vendor section, or you can use a clevis hitch and a brinley box blade that is what I have.
tgranthamfd
Last I heard stevebo had put the manual lift 3 points on the back burner for a bit. I, too, have a clevis hitch and a brinly box blade, works pretty good.
dustycarter
Ok. Thanks for the replys. How do you make a sleeve hitch for a WH and I belive I will try to make a box blade so i don't pay $200 for one. Any body have plans for either?
