chris11 184 #1 Posted May 23, 2010 Im looking to find out if any of the trans had double pulleys . And what model had it. Thank you Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted May 23, 2010 There were a few different diameters and widths, but all Uni-Drive input pulleys were single groove. Share this post Link to post Share on other sites
chris11 184 #3 Posted May 23, 2010 well ill have to make them then, wish i could beef up shaft size. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted May 23, 2010 I've heard a few horror stories of bending/breaking the end of the input shaft off when using double groove pulleys. Using wider single groove pulleys (3/4" belt width) and fabricating a stronger tensioner pulley arm assembly with a very heavy spring attached directly to it (instead of the arm on the opposite side) should help considerably with belt slippage. You'll want to lose the cheesy roll pin that secures the clutch linkage arm to the cross shaft too. :D Share this post Link to post Share on other sites
chris11 184 #5 Posted May 23, 2010 Thanks T maybe ill try the bigger belt. :D Share this post Link to post Share on other sites
