grandpa clair 0 #1 Posted May 23, 2010 while running tractor, fwd. movement stopped and will not move under own power. am able to push tractor freely without opening tow valve. anyone know what is wrong and how to adjust it? grandpa clair Share this post Link to post Share on other sites
KB9LOR 4 #2 Posted May 23, 2010 How is the tranny fluid level? Could the tranny filter be plugged, those are designed not to have a by-pass valve in them to prevent hydro damage if filter becomes clogged. hope this helps. Share this post Link to post Share on other sites
rickv1957 77 #3 Posted May 23, 2010 Hellom and Rick Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted May 23, 2010 :USA: What is the year/model of the tractor? Did you happen to check the axle to wheel hub woodruff keys? Share this post Link to post Share on other sites
grandpa clair 0 #5 Posted May 23, 2010 yes thanks rickv1957 I did check the woodruf keys, they are ok and I did check for fluid level, did not think about the filter. will check it out. Hydro press seems to be good as it raises the mower deck quite vigerously. Thanks KB9LOR Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted May 23, 2010 What is the year/model of the tractor? Can we get a hint? :D Share this post Link to post Share on other sites
grandpa clair 0 #7 Posted May 25, 2010 my tractor whith the hydro problem is a 79 model C-161-A Grandpa Clair Share this post Link to post Share on other sites
tophatbufflo 2 #8 Posted May 26, 2010 Try to adjust the friction on the directional control lever. Share this post Link to post Share on other sites
