hoppy 0 #1 Posted May 22, 2010 well it seems my list of to do's isnt getting smaller. my fiances aunt drove down her ford tractor she said "it isnt running right". Has a Kohler 14hp #M14AQS in it. spec #601512. here is what i found...................Walbro carb. I was curious as to why when i increased the throttle at the lever nothing change with the motor. i saw the cable moving the arm on the carb but the engine wasnt idling any higher. after further investigation i found the throttle arm brokn at the first screw at the throttle plate. no wonder it wouldnt idle up! the plate was basically all the way closed and since the arm is broken there is no way to get the rev up. i have searched pretty hard online and cant seem to find this part. its a bowl typ walbro carb and i need the arm the throttle plate screws to! anyone? Share this post Link to post Share on other sites
Buzz 502 #2 Posted May 22, 2010 Did you check this site?: http://www.kohlerplus.com/login.asp If you didn't, enter as "guest" then click in the Magnums, then M14 and finally the spec number 601512. There are three drawings for the governor with a breakdown of different linkages. Might help, might not. Is it possible to remove the broken part, have it welded and ground flat? That's might be one way out. Good luck. Share this post Link to post Share on other sites
hoppy 0 #3 Posted May 23, 2010 here is the piece i am talking about. im assuming this is brass. what can you weld brass with? kinda screwed unless i can find someone to weld it for me or i can find a replacement. will a JB weld material work for this and hold up? Share this post Link to post Share on other sites
linen beige 16 #4 Posted May 23, 2010 If nothing else, you (or a local machinist) can make a new piece from brass rod, available at any good hobby shop. Share this post Link to post Share on other sites
rick 266 #5 Posted May 23, 2010 Hoppy, see if you can find a number on the carburetor mounting flange like 47 053 64. Failing that, post the engine serial number. I am sure the part you need is Kohler # 47 144 36S, list price $14.53. To be positive, we need the numbers requested..... The question "How/why did the throttle shaft break?" MUST be answered, too. Is the lower end of the shaft frozen in the carburetor casting? Does the machine set out in the weather? Share this post Link to post Share on other sites
hoppy 0 #6 Posted May 23, 2010 rick, i will get that info up here abit later. i have to go cake taisteing right now. al cake is good so im not sure what trying 20 will do for us but hey one of those things you have to do i guess. not sure why/how it broke. i was easily able to remove the bottom half once i got the plate off. did not appear to be stuck, rusted. when i do align the two halfs up there does look like there is a slight bow/bend in the shaft.......maybe it got hit or maybe the wires have something to do with it? honestly i dont know the history of alot of the machines around here. since i have lived here i have become the "farm mechanic". i do know that these machines are much happier since i moved on the compound. been tuning up and fixing just about everything i can get my hands on. Share this post Link to post Share on other sites
rick 266 #7 Posted May 23, 2010 Enjoy the cake, hoppy! I will check back.... Share this post Link to post Share on other sites
hoppy 0 #8 Posted May 23, 2010 now i know why im marrying this girl! tux picked and ordered, cake tasted and picked and ordered and we stopped for brugers and dogs! left at 12:30 and home by 2:30! rick..........going to change and head out back for some numbers. have them on the digital but thats out back also. Share this post Link to post Share on other sites
stevasaurus 23,565 #9 Posted May 23, 2010 Sooo...you got your cake and ate it too. Sounds like congratulation may be in order. :USA: Share this post Link to post Share on other sites
rickv1957 77 #10 Posted May 23, 2010 Dont think JB weld would fix your throttle shaft,Rick Share this post Link to post Share on other sites
hoppy 0 #11 Posted May 23, 2010 here we go......................motor #'s. Model#M14AQS Spec #601512 SN#1802910483 carb #'s on flange......................4705364 and WHG063377 both carb numbers were on flange underside same as bowl what do you think? is this going to be a kohler part or walbro part? i would think walbro.................but then again im new to wheel horse tractors so i guess i really have no clue. anyway fellas(rick) what do you think? Share this post Link to post Share on other sites
rick 266 #12 Posted May 23, 2010 Congrats, hoppy! I am giving my youngest daughter away this coming Saturday. Kohler part number 47 144 36S is the part you need. Go to a Kohler dealer to get the part, he will most likely have to order it for you. You may want to take along your carburetor and broken shaft, he may have something in the junk box to fix you up. You can order it online, but the shipping will burn you a new one, more than the dealer markup. List price for the shaft is $14.53, shipping is usually @ $7.00 and up. Ask the dealer about freight charges, if you are willing to wait for a stock order, there may not be any. Good luck! PS: looks like you are missing a screw to hold the throttle valve to the shaft? Share this post Link to post Share on other sites
hoppy 0 #13 Posted May 23, 2010 rick..............thanks bud!!! i will check with a local dealer and see what they ahve or what they can get. as for the screw.......i have it. i had to remove the plate to get the bottom broken 1/2 out of the carb. i just couldnt work it to come out screwed onto the shaft. i will keep you updated on what i find. thanks for your help! and yes folks..............im tying the knot August 14th. Share this post Link to post Share on other sites
rick 266 #14 Posted May 24, 2010 You are most welcome, hoppy Share this post Link to post Share on other sites
