dave24 18 #1 Posted May 21, 2010 hello, my wheel horse 1045 transmission is having some troubles. every once and a while it wont kick into gear and sometimes when it gets into gear i will let off the clutch and it will be froze and the belt will squeel. does anyone know wats wrong with it or how to fix it? thx david Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted May 21, 2010 Time to crack the 'ole 5045 transmission case. You've got pieces-parts floating around in there. Something is broke inside and jamming the gears. Only way to find out and fix it is to do a little exploratory surgery, before you damage the innards further. Have fun! Here's the manuals: Mechanical Transmission Manual :D Share this post Link to post Share on other sites
stevasaurus 23,341 #3 Posted May 21, 2010 Dave...along with the information that Mike gave you...check out this thread...this is the same trans as yours. http://www.wheelhorseforum.com/index.php?showtopic=17168 :D Share this post Link to post Share on other sites
