WH854 45 #51 Posted July 25, 2010 :wh: csy33 I will try to explain the way I do it 1 You find a good level spot. 2 Let the deck all the way down with your lift 3 Loosen the mule drive belt with the knob on mule drive 4 Take belt of center pully of mower 5 Push the button on the tack-amatic I think it will be on the left side,There is a claw like gaget swing it towards the front of tractor,that will let the front of the mower hanger drop down hopefully. 6 Look under about the middle of the tractor you will see the lift arm, it fits in a kind of elonggated slot,you will have to wiggle the lift peg out of the slot. On an automatic with Hydro lift like mine I loop a little cord on the lift to hold it up out of the way So I can slide the deck out.(Right Side) or the handle to rase the back wheels (will not come out from the left side with that handle sticking up it will not clear the under side of tractor. 7 With a lot It should come out The right side Hope I made it clear for you Chas :thanks: 1 Share this post Link to post Share on other sites
WH854 45 #52 Posted March 22, 2013 How did that get on here? Chas Share this post Link to post Share on other sites
