blaster
k181 starter
blaster
Hi folks, Is there supposed to be shims behind the starter on my k181? I could have sworn there were two thin washers between the block and the mount. I put it on with washers and the pinion gear looked like it lined up good but when I started it it stuck and took about half the teeth off the pinion :D I don't want to have a repeat with my new starter. thanks....Glenn
