tmix 34 #1 Posted May 18, 2010 12 RAIDER-- Kohler MOTOR 2 wires coming from stator plate going to rectorfier DOES it matter what wire goes were they are not color coated. There are 3 plugs on the rectorfier 2 that go to the stator and the other one to the key which would be power PLEASE HELP ! TOM I don't want to hook them up wrong !!! THANKS GUYS :D Share this post Link to post Share on other sites
rmaynard 16,701 #2 Posted May 18, 2010 The wires from the stator connect to either AC lug on the rectifier. The other lug on the rectifier is B+ and is the output where the 14V DC comes from. The stator produces AC voltage which is non-polarized. Either stator wire can be connected to either AC lug. The B+ lug on the rectifier goes to the key switch. Bob Share this post Link to post Share on other sites
WH nut 553 #3 Posted May 21, 2010 Maynard got it, and I believe the center terminal goes to the key Share this post Link to post Share on other sites
tmix 34 #4 Posted May 22, 2010 thank you Did NOT want to blow somthing out tmix works great Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted May 23, 2010 I believe the center terminal goes to the key Not always...... There were different terminal configurations and different manufactures, so the B+ terminal could actually be any one of the three. It might take some cleaning and maybe even a magnifying glass, but you should see "B+" stamped or cast near one of the terminals, and "A.C." near the other two. Share this post Link to post Share on other sites
