puddlejumper 67 #1 Posted May 18, 2010 I have studied this visually without seeing any problems but I am going to ask before jumping the gun. Is there any reason why I could not put quick detach deck mounts on the 552 and still use the old original deck. If so is there any problem swinging the newer deck under the tractor(its in perfect shape with I think original wheels and serial tag) But I would prefer to use the old one. the reason I ask since I am building the 552 modified to use I would like to quick change between deck and front blade. Not sure yet about the duals I believe they are a little short to look right. Share this post Link to post Share on other sites
stevasaurus 23,456 #2 Posted May 18, 2010 That looks like a RM-366 deck on the left...I have no problem using that type of deck with the attach-o-matic on my 702 and 857...which are like your 552. Works great. I do have to jack up the front end with a jack because of the arm that attaches to the lift bar...just won't get low enough to slide under the horse. Other then that...no problem at all. But the blade should attach to the attach-o-matis on the rear axle...the deck would attach to the front. Anyway...no problem. Share this post Link to post Share on other sites
puddlejumper 67 #3 Posted May 18, 2010 thanks steve :D Share this post Link to post Share on other sites
