acsousa82 5 #1 Posted May 17, 2010 Just picked up a sweet C-105 with a solid k241. (Thanks Lew ) I was looking to retire my 753 from lawn duty, it just broke my heart to see grass clippings on her. I wanted a WH with at least a 10 hp engine and wider deck, not to mention something a little more comfortable to cut 2 acres of grass. The c-105 not only had what I was looking for, but was the right price, next town over, and I met a REDSQUARE member! She needed a new battery but started right up w/ no smoking or knocks and rides smooth. I was just wondering if anyone knew where I could obtain a manual for this model (couldn't find manuals past 1977 on the yahoo group) and if the hi/low transmission took the standard sae90 or the like that the older unidrives use? Check out pics!!!! Share this post Link to post Share on other sites
tgranthamfd 29 #2 Posted May 17, 2010 Nice C, I really enjoy mine you will too. What's up with the spark plug in the exhaust pipe? I just redid my lighting system and charging system, along with a good tune up and it is a joy to drive. Mine is an 80 model, not sure what it was but it is a 145 8 speed now. :USA: Share this post Link to post Share on other sites
mavfreak 11 #3 Posted May 17, 2010 plug in exhaust? did they like flames out of pipe? only have i seen that on 50s hot rods Share this post Link to post Share on other sites
rickv1957 77 #4 Posted May 17, 2010 God looking C105 there!,Rick Share this post Link to post Share on other sites
acsousa82 5 #5 Posted May 17, 2010 Thanks Guys! What's up with the spark plug in the exhaust pipe? I'm told that there was once a flame thrower installed For now it makes for a good conversation piece, not to mention plugs up the nice hole that was drilled. What viscosity tranny fluid do you guys recommend for the hi/low? SAE90? Share this post Link to post Share on other sites
Irv 115 #6 Posted May 18, 2010 I use the 85-120 in mine from Advance auto. Takes 2 qts. Share this post Link to post Share on other sites
formariz 12,354 #7 Posted May 18, 2010 It looks like you are becoming a tractor hoarder.Where did you pick up that habit? :D Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #8 Posted May 18, 2010 Alex, Nice machine !! Question is which one will you use at the show to mow the field for Uncle Bo and I this year??? Share this post Link to post Share on other sites
Suburban 550 28 #9 Posted May 18, 2010 Nice find, Alex. Good Luck with it. :D Share this post Link to post Share on other sites
VinsRJ 723 #10 Posted May 18, 2010 Nice find and good luck. Share this post Link to post Share on other sites
acsousa82 5 #11 Posted May 18, 2010 It looks like you are becoming a tractor hoarder.Where did you pick up that habit? Something about an acorn not falling far from the mighty oak, or something like that. Question is which one will you use at the show to mow the field for Uncle Bo and I this year??? hhhhhhmmmmmmmmm, I never had a choice before Either way Stevebo you will have a nicely cut lawn for that firepit. I think I heard something about adult beverages??????????????? :wh: Share this post Link to post Share on other sites
