rmaynard 16,533 #1 Posted May 14, 2010 Just rebuilt (if you can call it that) my Carter carb off of a K241AS. When I say "if you can call it that", I am referring to the very limited Kohler rebuild kit that includes a gasket that goes nowhere, a bowl gasket, float valve and seat. I removed and cleaned the idle fuel adjustment, main fuel needle and jet. I soaked and cleaned the carb body. Reassembled, set the needle valves to initial book settings, and started it up. It started right away after the bowl filled. However, there was a lot of popping and misfiring. Before I did anything else, I cleaned and regapped the points to .020", cleaned and set the plug to .025". I restarted and set the speed to fast and adjusted the main needle valve until the engine ran fairly smooth. Then I returned to idle and it quit. There does not seem to be difference wherever I set the idle needle valve. I removed the carb, re-cleaned everything, and check the needle valves, reassembled and it does the same thing. I still get popping and misfiring at high speed, and no idle. So I took the carb off my B-100 K241S. Without changing anything, I installed it on the K241AS and it runs fine. What am I doing wrong with the other carb, or where should I look next as far as a clogged port or something? Help. Thanks guys. I know someone will have the answer. Bob Share this post Link to post Share on other sites
piecrazy4 0 #2 Posted May 14, 2010 Sounds like the idle passage could be plugged or you could have a loose throttle shaft making it loose vacuum. Causing it to not get fuel? Maybe you should try disasembling it again and blowing out the passages with compressed air. Share this post Link to post Share on other sites
rmaynard 16,533 #3 Posted May 14, 2010 Maybe you should try disassembling it again and blowing out the passages with compressed air. Done that three times already. Share this post Link to post Share on other sites
The Toolman 22 #4 Posted May 14, 2010 What about all the little holes at the top an bottom of the high speed needle? I had ta run a real small needle thru mine to open'em up so it would idle. Share this post Link to post Share on other sites
rmaynard 16,533 #5 Posted May 15, 2010 What about all the little holes at the top an bottom of the high speed needle? I had ta run a real small needle thru mine to open'em up so it would idle. Check & double check. That's been done. I am going back to the old float valve and seat. I did not try to run the engine before installing a new valve and seat. I am going back to the old one to see if there is any improvement. Bob Share this post Link to post Share on other sites
rmaynard 16,533 #6 Posted May 15, 2010 FIXED! Thanks to T-Mo and his link to carburetor rebuild, (Carburetor 101), I discovered that the large needle valve was clogged INSIDE. The little holes were open, but between the top holes and the bottom holes, the passage was blocked. I soaked in 99% alcohol, and sucked on the tube until air passed. Sounds crude, but it worked. Thanks again to T-Mo for posting a comprehensive rebuild tutorial. Bob Share this post Link to post Share on other sites
W9JAB 156 #7 Posted May 18, 2010 :USA: I soaked in 99% alcohol, and sucked on the tube That's my hobbie to! :D Share this post Link to post Share on other sites
