jachady
Picture of rear lift tube
jachady
Does anyone have a picture or parts diagram of the guide tube for the rear lift on a Hydro tractor? I need one for my 314 but don't have time to order one, so I may have to make my own. I need the picture to either be on the tractor or with some dimensions.
Thanks
HankB
They're different depending on whether it is a hydro or manual. You can find a picture if you look up tiller at https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro and enter model # 79370 and the diagram for Rear Axle Mount Hitch. I found the following diagram.
Edit: full size image at https://lookup3.toro.com/Ill/2x/19/19150/_7840006.gif
If you can make one that fits the hydro, you're a better fabricator then me! I fiddled for a couple hours trying to get something to fit and then ordered one.
jachady
My issue is trying to figure where it gets routed. I could route it where I want but I'm sure Toro engineered it to work best in the position they have it.
HankB
The clamp - #9 in the picture - holds the end under the seat. On the hydro, it snakes between the hydro pump and the differential. The forward end lines up with a hole in a vertical plate beneath the frame.
