rick 257 #1 Posted May 11, 2010 Thinking about buying one, just wondering if it any good at drive way work.... Thanks in advance for any feedback! Share this post Link to post Share on other sites
jla1257 2 #2 Posted May 11, 2010 I can not say what the Brinly is like, but I am also thinking about getting one. In my searching I found that Agri Fab makes one as well that is 4" wider but about 20 lb heavier. http://www.agri-fab.com/products/45-0265.aspx. Do not know why but I am leaning towards the Agri Fab. Share this post Link to post Share on other sites
wingrider 21 #3 Posted May 11, 2010 I came across a IH box scraper a while back that was easy to hook up to the rear tach a matic and picks up with the rear cable hookup. I've used it for several years on my drive/parking area to keep it in good shape. Also made a angle iron bracket on top to fit 3 concrete blocks on if I need extra down force. Good hunting and enjoy. Wingrider Share this post Link to post Share on other sites
gwgdog66 23 #4 Posted May 11, 2010 I've got one, and it works really well. Share this post Link to post Share on other sites
jtmoyer 1 #5 Posted May 12, 2010 i have an an agri fab and i used to put in a drive. i tilled it and then used the scraper blade to pull out the dirt. it worked good if i had the rest of the family stand on the blade. the weight box is to low and will act as a skid if you want to dig in. if you are just leveling out it should work fine.you tend to bend the small bolt that keeps the blade straight though if you work it to hard. Share this post Link to post Share on other sites
rick 257 #6 Posted May 13, 2010 Thanks, guys. Any more feedback? Share this post Link to post Share on other sites
