Raider12 13 #1 Posted May 6, 2010 I just tuned up the deck (nothing major) and reinstalled it back on the tractor and now the PTO belt wants to flip over and run on it's back side. It has done this before (years ago) and I replaced the belt and was good. But this belt is in great shape and was new last season. Anyone run in to this? If I correct the belt, as soon as I engage the the PTO it will flip and run on it's back again right away. Share this post Link to post Share on other sites
CasualObserver 3,411 #2 Posted May 6, 2010 Try taking it back off, and actually flipping it over... maybe you put it back on in the reverse rotation that it's used to and it doesn't like it. :D Share this post Link to post Share on other sites
W9JAB 156 #3 Posted May 6, 2010 Belt flip is normally a problem with misalignment of the pulley or worn out pulleys. Share this post Link to post Share on other sites
WheelHorse_of_course 100 #5 Posted May 6, 2010 Another mistake I have made a few times in the past is getting the belt between the top and bottom sheave of the deck spindle. It kinda works, but not for long! PS: the other thing about these old-style decks is the fact they do not like to be run when the deck is in the UP position. Share this post Link to post Share on other sites
piecrazy4 0 #6 Posted May 6, 2010 My RL-426 doesn't have any problems in the up position what are the problems ? Share this post Link to post Share on other sites
rickv1957 76 #7 Posted May 6, 2010 Are all of the idler bearings good?,Rick Share this post Link to post Share on other sites
Raider12 13 #8 Posted May 7, 2010 Are all of the idler bearings good?,Rick Yep. all the bearings are good and the pullies run nice and striaght and true. I think the problem is the belt it self. I put an old belt back on from years ago (kept for a spare) and it runs perfect. Can anyone tell me what size belt is "Supposed" to be used? I currently using a NAPA 4L690W Share this post Link to post Share on other sites
catman81056 3 #9 Posted May 7, 2010 Your pic looks like the right routing, is it flipped in the picture? I think Jason is on to something, twisted belt. I did away with the older style deck/pully system. Put a deck off a 1975 C100 on my 1267. Just had to add a front tach-matic, change right side tach-matic brkt, the newer mule drive, and a 102" belt. Works fine. Share this post Link to post Share on other sites
catman81056 3 #10 Posted May 7, 2010 Parts tree has the belt for $17.04 part #9782, replaces #6737 Share this post Link to post Share on other sites
Raider12 13 #11 Posted May 7, 2010 Your pic looks like the right routing, is it flipped in the picture? I think Jason is on to something, twisted belt. The photos show the belt in the correct position, but as soon as I ingage the pto, it will flip upside down. I took the belt off tonight and it was on correct. There must be something broken with in the belt it self. The belt I have on now is work just fine and it has a lot of wear. I 'll buy a new belt tomorrow and see if this corrects the problem. It just doesn't make sense that it work just fine until I took the deck off? Go figure Share this post Link to post Share on other sites
WheelHorse_of_course 100 #12 Posted May 7, 2010 Your pic looks like the right routing, is it flipped in the picture? I think Jason is on to something, twisted belt. The photos show the belt in the correct position, but as soon as I ingage the pto, it will flip upside down. I took the belt off tonight and it was on correct. There must be something broken with in the belt it self. The belt I have on now is work just fine and it has a lot of wear. I 'll buy a new belt tomorrow and see if this corrects the problem. It just doesn't make sense that it work just fine until I took the deck off? Go figure I agree with the suggestion that perhaps the belt was flipped while it was off. Obviously it should not matter, but with a used belt I could imagine it wore/stretched in a particular way so that everything was no longer symmetrical. Always good to have a new or used spare - well done! :D Share this post Link to post Share on other sites
