mowerman1193 42 #1 Posted May 5, 2010 Going to be swapping a 14 hp from a Bronco 14 into a C-120...Anyone know what all I might run into to swap this out? I will need to swap PTO stuff around as the Bronco has a electric PTO and I believe the C-120 has manual PTO..Not real sure if its a C-120 or it may be a C-121..As far as looking to two over it looks like they should be a easy bolt on swap..More worried about swapping the PTO stuff..Maybe I should just hook up the electric PTO on the C series?? Doing this for my uncle..probably could end up with the Bronco without a motor when i am done, LOL Kinda rough but is complete and he was using it until the wiring shorted out and burned all up..Hopefully nothing happen to the charging system as I have never worked on any charging systems other than on cars, LOL Anyway anyone have any advice or suggestions on doing the swap.. Kevin Share this post Link to post Share on other sites
rickv1957 77 #2 Posted May 5, 2010 Motors will swap if you have a C120,it will bolt in and on the C121 you will have to remove the rubber mount cradle,Rick Share this post Link to post Share on other sites
