Countdown To Christmas!
abrown0920
slot hitch
abrown0920
The slot hitch on my tractor is stuck. It barely moves even when beating it with a hammer(rubber mallet) I have tried soaking it in penetrating oil and nothing is helping. Any ideas as to why and how to fix it?
rickv1957
Apply some heat along with WD40 and work hitch back and forth,it will free up,Rick
Kelly
Heat and PB blaster, Heat and PB blaster, Heat and PB blaster, Heat and PB blaster You get the idea :D
linen beige
Like the others said, just keep lubing, heating and moving, lubing, heating and moving, until you get it freed up. Then, it isn't a bad idea to keep working with it until you can remove the pivot pin. Pull, drive, or press it out and clean ALL the rust/crud from it AND the hole in the tranny and hitch. Grease it up good and reinstall it, OR replace it with a large hitch pin that has a handle on it. The pins with handles can be easily wiggled from time to time to keep them rotating freely.
abrown0920
My goal is to get the pin out for paint and clean up. Should it have to be pressed out or should it slide out. I noticed there are not any retainer clips on the ends of mine but I figured there where supposed to be.
d180man
Hi it should slide out when you get it free !! just keep working on it !! :D you will get it ! :USA: :wh:
linen beige
Examine the ends of the pin very closely checking to make sure the ends aren't mushroomed out. If someone else has tried to pound it out and ended up mushrooming the ends they will need to be filed back to round so you can get it out.
Lane Ranger
As has been stated above a 3/4 inch hitch pin from TSC or another rural supply store that is about 6 1/2 to 6 and 3/4 inches long with a pull handle on one end is a great way to go to repalce the pin in the rear of your transmission. You can change hitches much easier or interchange them.
Here is a photo on the back of a 1964 Wheel Horse 1054 with two hitches :
This works great and is an upgrade in my opinion!!
:D
