boovuc 1,090 #1 Posted May 1, 2010 Hi Guys, I took my C-175 to a local dealer who dealt WheelHorse in the past. This tractor has been acting up for a year or two. You smell like a diesl mechanic after running it. Most times you needed to run it with the choke open. New plugs, air cleaner, gas filter, points condensor. The whole shabang. I took it to the old dealer to have them rebuild the carb. Got it back and it sat a month before I changed out the oil and put the mower on it. At first it was fine......then...........it would loose power like it was running lean, then come back. I'd go over a bump or let the clutch out strong and it would spit and sputter then come back. After it got really warmed up, it just ran like crap. I stopped and did a re-tune of the hi/low idle screws and it was running great on the driveway sitting still. When I engaged the mower and ran it, it started again before just quiting! Turns out I then needed to run it in full choke!? My guess is the float! Please give me a second third and fourth opinion please! I'm taking it back! It worked before I had them do it. It needs corrected! PS.....I really smelled like a diesl mechanic after that ride! Thanks, Boovuc Mill Hall, PA Share this post Link to post Share on other sites
rickv1957 76 #2 Posted May 1, 2010 Sounds like you still have carb problems, Rick Share this post Link to post Share on other sites
b-80boz 0 #3 Posted May 2, 2010 take the carb off and look at the valves mine kept doing that and it was one of the screws holding the filter on had come out and got stuck in the valve its worth a try it solved my problems!! Share this post Link to post Share on other sites
