malibumike388 0 #1 Posted May 1, 2010 my new wheel horse it is a 1970 gt 14. gonna repaint it.just got to do alittle tinkering with the carb and check trnas fluid.because it'll move when i have it on jack stands but not when its not.it sounds like a sucking sound. but the lift works. Share this post Link to post Share on other sites
whfan74 2,073 #2 Posted May 1, 2010 Nice, straight looking tractor! Congrats on your new toy! Share this post Link to post Share on other sites
malibumike388 0 #3 Posted May 1, 2010 thanks.i hope the trans isnt shot. where these painted with the white grill from the factory or did someone paint it this way? Share this post Link to post Share on other sites
whfan74 2,073 #4 Posted May 1, 2010 Someone painted it that way............ Good luck with the tranny! Share this post Link to post Share on other sites
rickv1957 77 #5 Posted May 1, 2010 Nice tractor,make sure the tow valve is closed, Rick Share this post Link to post Share on other sites
Ole MN 11 #7 Posted May 1, 2010 Nice looking 14, your going to enjoy it they are a great tractor Share this post Link to post Share on other sites
malibumike388 0 #9 Posted May 1, 2010 i looked at the sticker under the seat and it said to have the valve facing forward and thats how it is. btw i saved this from the scrap yard Share this post Link to post Share on other sites
HankB 16 #10 Posted May 1, 2010 btw i saved this from the scrap yard Nice save! and good luck getting the trans sorted. Share this post Link to post Share on other sites
malibumike388 0 #11 Posted May 1, 2010 well i found out its out of trans fluid.what can i use for it cant find type a trans fluid. Share this post Link to post Share on other sites
HankB 16 #12 Posted May 1, 2010 well i found out its out of trans fluid.what can i use for it cant find type a trans fluid. There has been considerable discussion of this lately. My chart shows that the GT-14 used a Sundstrand transmission. Older ones used Type-A ATF and later ones apparently switch to 10W-30 or 10W-40 engine oil. There is apparently also documentation stating that the older ones could be switched to engine oil if all of the old ATF was removed (by serial changes of oil.) The simplest solution is to see what's in it now and match that. I would guess it has ATF as I think that's what those came with from the factory. Type-A may no longer be available but I seem to recall hearing you can use Dexron. Edit: Here's the other thread: http://www.wheelhorseforum.com/index.php?...17912&hl=dexron Share this post Link to post Share on other sites
papaglide 542 #13 Posted May 1, 2010 The service updates at my local ex-wheel horse dealer stated that Dexron II or Mercon ATF is the now recommended tranny fluid for a model GT 14. Share this post Link to post Share on other sites
malibumike388 0 #14 Posted May 6, 2010 well i started to tare it apart.just gonna repaint and put in new bolts.just a quick paint job.if i had the money i would've had the pieces sandblasted maby next time. its gonna be krylon cherry red i masked off all the decals they wore in good shape.i just hope its not a waste of time. because i dont know if the trans is shot.i will take pics when its done. i was thinking about putting a stack on it. and what do u think it will be worth when its done? thanks,mike Share this post Link to post Share on other sites
malibumike388 0 #15 Posted May 18, 2010 alittle bit of progres Share this post Link to post Share on other sites
Raider12 14 #16 Posted May 18, 2010 Your at least making some progress. Looking good so far. Share this post Link to post Share on other sites
MRM 4 #17 Posted May 18, 2010 Looks good, Wish i had a GT14 Share this post Link to post Share on other sites
malibumike388 0 #18 Posted May 21, 2010 got the back fenders on and seat took the tape off the decals on the hood Share this post Link to post Share on other sites
Lawn Ranger kid 14 #19 Posted May 21, 2010 Looks great. Josh Share this post Link to post Share on other sites
rickv1957 77 #20 Posted May 21, 2010 Tractor is looking great!,Rick Share this post Link to post Share on other sites
malibumike388 0 #21 Posted May 22, 2010 getting ready to do some final touch up on the paint and gonna repaint the wheels then gonna rebuild or refresh the engine. Share this post Link to post Share on other sites
