buster 2 #1 Posted April 30, 2010 How difficult would it be to replace the original Kohler Magnum 12 found on a 312-8 with the Kohler CH15S engine. Can you remove the fuel tank on the CH15s and use the frame mounted fuel tank? Do you need some type of engine plate for the swap? Also, can you hook up the dash mounted throttle lever to this engine? Thanks for the help. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted April 30, 2010 Toro did it (the last "Classic" 315-8 models) so I'm sure you can do it with their help. This will get you to the IPL's @ PartsTree: LINK Share this post Link to post Share on other sites
Audioshot 2 #3 Posted May 2, 2010 I thought about doing something like this too. Share this post Link to post Share on other sites
