ricksrj58 273 #1 Posted April 29, 2010 heres a pic of my starter i need to replace.it has no numbers or end plate on it. another member posted this number 33835 but it comes up as a square starter with 3 mounting points and 11 teeth.my starter has 2 and 10 teeth. Share this post Link to post Share on other sites
rickv1957 75 #2 Posted April 29, 2010 Will check a couple of mine for a number,Rick Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted April 29, 2010 The original round-case starter is #32817. Don't be surprised when you see what the # on the new replacement is. :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted April 29, 2010 By the way....... You can also used the motor portion of the 32468/32468A starter with your nose bracket and drive if you want to build a "franken-starter". You just have to turn the housing 180 Share this post Link to post Share on other sites
family tradition 0 #5 Posted April 30, 2010 191.00 plus i just bought a new one Share this post Link to post Share on other sites
rickv1957 75 #6 Posted April 30, 2010 Ouch!,priced a starter for an Onan a while back 286.00,find an aftermaerket for 60.00 thats working great so far,Rick Share this post Link to post Share on other sites
family tradition 0 #7 Posted April 30, 2010 191.00 was for a 8hp kohler thats not including tax. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted April 30, 2010 191.00 was for a 8hp kohler thats not including tax. He must have seen you coming. The first one I looked at: http://www.smallenginesuppliers.com/shop/agora.cgi/15956 Pat's Small Engine Plus (in MN) has them for $84 shipped! New aftermarket starters seem to be around $60 - $70. Share this post Link to post Share on other sites
ricksrj58 273 #9 Posted April 30, 2010 hey TT the numbers you first gave me is the replacement starter right, thats why i am going to be surprised. well thanks for the info guys. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted April 30, 2010 Yes, Rick - everything I looked up went to the "new" number. (33835) I actually checked the round-case starter on my '70 R-10, so I know the original number (32817) is correct. I had one or two HH-100's with the square (replacement) starters and know they work fine. I think the different mounting bracket spaces them away from the block just enough to allow the drive gear with the extra tooth to mesh correctly with the ring gear on the flywheel. Share this post Link to post Share on other sites
ricksrj58 273 #11 Posted April 30, 2010 ok . so thats how that works :omg: Share this post Link to post Share on other sites
