tranders 0 #1 Posted April 28, 2010 Rewiring my 653(8HP Kohler with starter generator) and noticed in the wiring diagram there was no mention of fuses. Should there be fuses and where? Thanks. Share this post Link to post Share on other sites
stevasaurus 23,883 #2 Posted April 28, 2010 Rob, you are right...looked all over my 1962"s...no fuse box. You may have some in line, or could put them in if you want. Must not have needed them back then. :omg: Share this post Link to post Share on other sites
stevasaurus 23,883 #3 Posted April 28, 2010 Had a problem with the post function.....needs a fuse. :omg: Share this post Link to post Share on other sites
CasualObserver 3,417 #4 Posted April 28, 2010 What wiring diagram are you using? The 653 was originally a Tecumseh 6hp tractor... which requires a different schematic than a K-181 Kohler. If you have the Kohler, and need to wire it up, try using the diagram for the either the 753 or the 854 depending on what starter switch setup you are using. And no... there were not any fuses originally. Share this post Link to post Share on other sites
tranders 0 #5 Posted April 29, 2010 I'm using the 753 schematic. Looks like no fuses then. Thanks for the help. Share this post Link to post Share on other sites
