Countdown To Christmas!
tranders
Rewiring 653
tranders
Rewiring my 653(8HP Kohler with starter generator) and noticed in the wiring diagram there was no mention of fuses.
Should there be fuses and where?
Thanks.
stevasaurus
Rob, you are right...looked all over my 1962"s...no fuse box. You may have some in line, or could put them in if you want. Must not have needed them back then. :omg:
stevasaurus
Had a problem with the post function.....needs a fuse. :omg:
CasualObserver
What wiring diagram are you using? The 653 was originally a Tecumseh 6hp tractor... which requires a different schematic than a K-181 Kohler. If you have the Kohler, and need to wire it up, try using the diagram for the either the 753 or the 854 depending on what starter switch setup you are using. And no... there were not any fuses originally.
tranders
I'm using the 753 schematic.
Looks like no fuses then.
Thanks for the help.
