b-80boz
pulley
b-80boz
I bought an air comp. with I THINK IS A 12 HORSE MAGNUM ON IT I`m wanting to put this on an older sears suburban. It has a pulley on it that I`m not sure how it will come off. IT HAS 3 BOLTS ON THE FACE of it I took those out but I still can`t get it to budge .Is there something else I need to do or should I just try a puller and a mallet I cant find any set screws on it just wondering if anyone has a trick up their sleeve on getting this off. Any help would be appreciated thanks. :omg:
W9JAB
it sounds like you have a "split taper bushing"
type of sheave (pully) if you do, take a look at the holes
around the bushing 1/2 will be threded 1/2 will be thru
holes.
Take the bolts out of the thru holes and put them in
the threded holes, as you thighten them up evenley
it will work as a puller and separate the two parts.
if this is not what you have please post a pix.
b-80boz
thanks for the info I was thinking the same thing about using the bolts as a puller but wasn`t sure I didn`t want to mess something up that is exactly what kind of pulley it is I didn`t know the name of them I really apreciate the help :omg:
TT
Formally know as a "quick detachable" or "QD" bushing.
Here's some informative reading courtesy of Allied Bearings Supply:
QD bushings
