kpthorsefan 34 #101 Posted May 29, 2011 Today have been making the shaft for the chain to attach to, its a good job i have got the C-121 i can use to measure and fit it to before it goes on the C-141, next is to sort out the cable that goes to th lift arm.. Share this post Link to post Share on other sites
AMC RULES 37,259 #102 Posted May 29, 2011 Boy Kevin, you do nice work. What attachment are you fabbing up the clevis for? :WRS: Share this post Link to post Share on other sites
kpthorsefan 34 #103 Posted May 30, 2011 Boy Kevin, you do nice work. What attachment are you fabbing up the clevis for? Thanks for that craig , the hitch is for my brinly plow which is half way through being sprayed and going back together . Share this post Link to post Share on other sites
kpthorsefan 34 #104 Posted May 30, 2011 I went into my workshop today to measure up the cable i will need for the hitch and get one made up, I then played about with a piece of 1/4" steel rod, put threads on both ends made two trunnions on the lathe, got two r clips some washers and a lot of adjusting, and guess wot!! it works a treat Share this post Link to post Share on other sites
massey 119 #105 Posted May 31, 2011 Nice work there. Share this post Link to post Share on other sites
kpthorsefan 34 #106 Posted May 31, 2011 Nice work there. Thank you massey, I did the same thing with my snow plow some time ago replaced all the cables with steel rod.. Share this post Link to post Share on other sites
kpthorsefan 34 #107 Posted May 31, 2011 The top coat goes on tomorrow.... Share this post Link to post Share on other sites
kpthorsefan 34 #108 Posted June 1, 2011 First coat of paint on................. Share this post Link to post Share on other sites
kpthorsefan 34 #109 Posted June 3, 2011 Hitch all finished and fitted and it works a treat!!!!!! . Now i can get on putting the brinly plow together.... Share this post Link to post Share on other sites
GT14 243 #110 Posted June 3, 2011 Very nice! :hide: Share this post Link to post Share on other sites
kpthorsefan 34 #111 Posted June 4, 2011 Very nice! Thanks for that GT14............. :WRS: Share this post Link to post Share on other sites
kpthorsefan 34 #112 Posted June 5, 2011 Let the old girl out today , She has not seen a lot of day light for a while. so here she is.... Share this post Link to post Share on other sites
mavfreak 11 #113 Posted June 5, 2011 I love the tri rib tires and ags on the back. Makes it look more like a tractor rather than a lawn mower! Share this post Link to post Share on other sites
kpthorsefan 34 #114 Posted June 5, 2011 I love the tri rib tires and ags on the back. Makes it look more like a tractor rather than a lawn mower! Lawn mower ?. Well i cant see a deck on it, I would go for a garden tractor ... but what ever......... Share this post Link to post Share on other sites
mavfreak 11 #115 Posted June 5, 2011 sorry you need to read what I posted a little better or maybe I can explane a little better. When I look at the tire you put on your garden tractor it makes it look like a farm tractor.... When I see a grarden tractor with truf tires to me they look like lawn mowers. Now read what I posted again.... I love the tri rib tires and ags on the back. Makes it look more like a tractor rather than a lawn mower! When I get enough saved I'll be doing the axact same thing as you have! I already have the hubs and front wheels but tires are so expensive so some day. Great looking tractor Share this post Link to post Share on other sites
kpthorsefan 34 #116 Posted June 5, 2011 sorry you need to read what I posted a little better or maybe I can explane a little better. When I look at the tire you put on your garden tractor it makes it look like a farm tractor.... When I see a grarden tractor with truf tires to me they look like lawn mowers. Now read what I posted again.... I love the tri rib tires and ags on the back. Makes it look more like a tractor rather than a lawn mower! When I get enough saved I'll be doing the axact same thing as you have! I already have the hubs and front wheels but tires are so expensive so some day. Great looking tractor Perhaps its me a bit slow ? But its never had turf tires on it, well not since i bought it anyway..... :WRS: Share this post Link to post Share on other sites
kpthorsefan 34 #117 Posted June 5, 2011 Now this is my grass cutter.... Share this post Link to post Share on other sites
mavfreak 11 #118 Posted June 5, 2011 Is that one next to get freshened up now to cause it looks like a decent tractor also and you did such a nice job on the other one! Share this post Link to post Share on other sites
meadowfield 3,087 #119 Posted June 6, 2011 looking great kevin ! How easy is it going to be to lift the plough? looks like a lot of leverage to me... mark Share this post Link to post Share on other sites
kpthorsefan 34 #120 Posted June 6, 2011 Is that one next to get freshened up now to cause it looks like a decent tractor also and you did such a nice job on the other one! Hi heath, No this is my work horse, had this one for about ten years or more now and still gets worked well so wiil stop as it is , But gets well looked after. :hide: Share this post Link to post Share on other sites
kpthorsefan 34 #121 Posted June 6, 2011 looking great kevin ! How easy is it going to be to lift the plough? looks like a lot of leverage to me... mark Hi mark, I think it should be just fine, I have had someone standing on it while i pulled the lift lever and it worked ok..... But time will tell, the plough is nearly back together just waiting for one plough bolt to come, so i have ground to a halt till that comes. will let you know how it goes when its hooked up......... :hide: Share this post Link to post Share on other sites
meadowfield 3,087 #122 Posted June 7, 2011 if someone can stand on it then wow ! I'm going to make one... hopefully your pics have enough detail for me to copy thanks mark Share this post Link to post Share on other sites
kpthorsefan 34 #123 Posted June 7, 2011 if someone can stand on it then wow ! I'm going to make one... hopefully your pics have enough detail for me to copy thanks mark The plough is now all finished , decals fitted and hooked up to the C-141, It fits a treat and lifts no problem..... :hide: Share this post Link to post Share on other sites
meadowfield 3,087 #124 Posted June 7, 2011 :hide: I want to see it in action next.... mark Share this post Link to post Share on other sites
kpthorsefan 34 #125 Posted June 8, 2011 Here it is all hooked up....... Share this post Link to post Share on other sites
