TR_DIGGER 3 #1 Posted March 16, 2008 Looking for info on a White GT-1855 HydroMatic. Lot/Model 142-996-190/EG42H5 Thanks Ty Attached Image Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,742 #2 Posted March 16, 2008 I'm not sure, but it looks like it might be a MTD built White. The pulley on the front indicates it might be a horizontal engine one with the crank coming out of the front, but the opening in the frame also makes me wonder if it might have been a vertical shaft one (more likely). It's probably a MTD made one as there is a lot of plastic there. :thumbs: Share this post Link to post Share on other sites
combatmp29r 27 #3 Posted March 16, 2008 Well Ty I can tell you that half of yours is missing Other than that I can't help you much :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted March 16, 2008 It's a 1992 model built by White Outdoor Products. Looks like it had a Kohler horizontal twin (M-18?) and it has an Eaton M11 hydro with a Peerless transaxle. They also had an optional three point hitch. Here's the attachments that were offered for it: 190-985-190 54" Snow Blade (1992) 190-990-190 45" Snow Thrower Attachment (1992) 190-993-190 50" Mowing Deck (1992) I found out everything here from SEPW through the Sohar's parts viewer. Share this post Link to post Share on other sites
TR_DIGGER 3 #5 Posted March 16, 2008 Not too sure about this yet, but I was told the engine was a Briggs Twin V, and I think the shaft went towards the rear. You can see a shaft in the center of the pic below. And it is a MTD Joel, does this looks better? Terry, I do have a deck on it, just not sure what size yet and it does have some of the 3point hitch too Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted March 16, 2008 Ty -- here's the link to SEPW Click on the gray "Parts Lookup" box in the middle of the page. When it takes you to the Sohar's parts page, look in the top left corner for the "Select OEM" box, click on the arrow, and select "White Outdoor" from the list. If you select the model tab at the top left corner, there will be a box to enter your model number. Enter 142-996-190 in that box and click "search". When it refreshes, you will see the "Details" list on the right side of the page with the parts breakdown for the sub-assemblies. They have an 18hp Briggs opposed twin and were made by the wonderful MTD company. I have also read various posts about a poor rear wheel hub design that frequently breaks, but otherwise they're a decent tractor for what they are. Share this post Link to post Share on other sites
TR_DIGGER 3 #7 Posted March 16, 2008 Thanks Terry, that helps :thumbs: Share this post Link to post Share on other sites
combatmp29r 27 #8 Posted March 16, 2008 Yep much better TY :thumbs: Share this post Link to post Share on other sites
Rollerman 290 #9 Posted March 16, 2008 Ty there are some very knowledgeable & helpfull people on this site. I figured you get some fast info here. Hope your off in the right direction now...get this beast a runnin & take the work load off some of those nice horses you have. Thanks JD Terry,TT, & Joel for you input. Share this post Link to post Share on other sites
combatmp29r 27 #10 Posted March 16, 2008 Stephen you don't have to thank me for my input on this one. It was quite useless I'm sure :thumbs: Share this post Link to post Share on other sites
rustyoldjunk 127 #11 Posted March 18, 2008 what you have there is a very heavyduty tractor.its a newer version of the 990 mtd built in the late 60's into the 70's.they had 15 inch wheels.shaft drive hydro 3 point hitch,reinforced front spindels and heavyduty hubs a 49 1/2 inch wheelbase c channel frame and more these tractors are tanks.here is a good running heavyduty old workhorseim working on fixing up. its the grandaddy to your version. for more good info on these go to mytractor forum and check out the mtd subforum. jim Attached Image Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,742 #12 Posted March 18, 2008 Hey, Rusty. I think this is the first post I saw from you (even though your post count is at 3). I must have miss the other 2 posts. I just want to . I think I saw some posts of yours over on GW, if I'm not mistaken you for someone else. Keep posting and share you knowledge with us. :thumbs: Share this post Link to post Share on other sites
rustyoldjunk 127 #13 Posted March 18, 2008 thanks treed.as for posts,i mostly do that at mtf and lurk on the other sites. Share this post Link to post Share on other sites
blacksmithman 1 #14 Posted April 4, 2008 Here is the manual for that White tractor. http://manuals.mtdproducts.com/mtd/DocGett...oc=770-8560.pdf Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,742 #15 Posted April 4, 2008 Hey, Blacksmithman, It's good to see you here. :thumbs: Share this post Link to post Share on other sites
Kelly 1,037 #16 Posted April 5, 2008 As has been said these are pretty stout tractors for what they are and many are still around so can't be to bad. Share this post Link to post Share on other sites
TR_DIGGER 3 #17 Posted April 5, 2008 Thanks Blacksmithman, I can really use that I have a 16horse on it for now till I get the bugs worked out. It is running and moving. Thanks to you all for all the help. :thumbs: Share this post Link to post Share on other sites
TR_DIGGER 3 #18 Posted April 23, 2008 Well, the White will run but, seems I cant get it to start on it own. I have a circut breaker on it, could that be bad? and if that could be it, how can I test it to see? Share this post Link to post Share on other sites
